Battlefield 3 Problems
5 Dec 2008
Kent
Ok, I don't know how serious this problem is. I can play any other game (FIFA, Dead Island, LA Noire, Arkham Asylum) but BF3 won't start any more.
I get this error when I try to launch a game:
The resolution becomes shorter (still 1920x1080 though) and doesn't fit the screen. There is also a clicking noise that comes from the computer.
If for some luck the game does work, it is filled with graphical errors and unplayable.
I have updated every driver and the BIOS and nothing has helped.
Every other game runs perfectly.
Thanks.
UPDATE:
I have repaired the AMD drivers and used some software to override the ingame graphical settings and it seems to work for now.
Thank you for your help.
