Battlefield2042 Help
29 Mar 2007
just wondering a phew things as i cant find any decent forums for it,
and i have lost the manual :(
How come every time i play single player my points never get added :confused: ?
how do you win easy in single player mode, ive heard something about destroying the bases :confused:
Single player mode does not add points or have the larger more fun maps, you have to use Multiplayer to get points and play the better maps.
InvG
InvG
what about Winning, ive heard something about blowing the enemies base up ?
and so you have to play online against other people to go up stast and points :( okkkkk
thanks
InvG
thanks
thanks
If your playing titan mode, your aim is to take as many silos as possible to lower the enemy shield then attack the enemy titan, however if your playing conquest/ assult lines its completely different and mainly revolves around capturing certain flags and holding them to stop your tickets from running out.
