Battlefield4 my cpu fan or graphics card fan starts spinning faster
7 Sep 2012
St Annes, Lancashire
Hi
I have been playing Battlefield4.
My internal computer fans are spinning faster than usual.
CPU or Graphics card fan or both?
Is this normal?
thanks
Jonathan
probably gpu fan spinning up to keep card quiet look at your profile to see if its on auto. maybe change it to a fixed value.
Specs?
If you have high FPS you can limit the FPS to 60 or use vsync and this will drop temps and GPU usage to about 50-70%.
Processor (CPU) Intel® Core™i5 Quad Core Processor i5-3570 (3.4GHz) 6MB Cache
Graphics Card 2GB NVIDIA GEFORCE GTX 670 - 2 DVI, HDMI, DP - 3D Vision Ready
