Battlefront 2
6 Oct 2004
Widnes, Cheshire
Just a quick question, will my system run the above game @ 1440p and has anyone played the beta with a 980ti.
MSI gtx 980ti core 1400 mem 4000
i7 4770k @ 4.6
16 gig ddr3 2400
Thanks
MINIMUM REQUIREMENTS
OS: 64-bit Windows 7 SP1/Windows 8.1/Windows 10
Processor (AMD): AMD FX 6350
Processor (Intel): Intel Core i5 6600K
Memory: 8GB RAM
Graphics card (AMD): AMD Radeon™ HD 7850 2GB
Graphics card (NVIDIA): NVIDIA GeForce® GTX 660 2GB
DirectX: 11 Compatible video card or equivalent
Online Connection Requirements: 512 KBPS or faster Internet connection
Hard-drive space: 60GB
RECOMMENDED REQUIREMENTS
OS: 64-bit Windows 10 or later
Processor (AMD): AMD FX 8350 Wraith
Processor (Intel): Intel Core i7 6700 or equivalent
Memory: 16GB RAM
Graphics card (AMD): AMD Radeon™ RX 480 4GB
Graphics card (NVIDIA): NVIDIA GeForce® GTX 1060 3GB
DirectX: 11.1 Compatible video card or equivalent
You should be fine.
Why are they recommending an AMD 8 series cpu when Ryzen is available!
It could be because the consoles use an 8 core AMD and it's optimised for 8 threads?
EDIT: On reflection the 1700 and 6700k are similar in price so it's definitely more appropriate to recommend that!
