Battling a error 0x80041003 with no success!
24 Nov 2012
So ive came across the above error in win7 sp1 and although there appears to be some posts on it on google, ive not found any real conclusion. The event viewer (accessed in Safe Mode) gives me:
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
Which means nothing to me...
In the meantime, my rig is completely useless. When I boot, it will look fine and i'll log in, then ill open a folder and it'll go slow, and no program will open, and i'm just given the little windows loading circle forever and nothing will respond - I believe it is the Windows Explorer crashing? But i'm not sure. It works fine in safe mode.
Things I done directly previous to problem occurring:
installed borderlands 2
windows updated
After:
system restore to previous to windows update
uninstalled borderlands (im sure this isnt it but it did happen like 5 mins and 1 reboot after installation)
If anyone could help that'd be great, I just bought the rig a couple of months ago and really dont want there to be problems already.
PS: it also comes up telling me my AVG lisence is invalid since this problem began, but im running AVG free and this never once came up before? just makes me think it might be a virus or something...
