- 18 May 2020
Hello all.
I'm having some issues with the performance In Hell Let Loose, Every 20 seconds or so my CPU usage hits 100% and my game stutters badly for about 10 seconds then goers back to normal until It happens again, I have tried Proton Experimental and GE-Proton latest version but still no joy. any help would be appreciated
it is one on my list to play. Also those pesky shaders; they do require some patience. As an aside I also usually go the Proton Experimental and GE-Proton route, failing that I go Proton Experiment and switch to the beta bleeding edge for the odd game that doesn't behave, although I have had to switch to older versions on occasion usually as a result of a tip from Protondb (usually much older games).
