1 Jun 2008 at 09:26 #1 Paul11 Paul11 Soldato Joined 28 Sep 2003 Posts 10,407 Location London has anyone heard of this broadband will not work when we use a filter but will work without one ? the other extension which has a phone on it, has a filter but the phone line is very very noisy ? thanks in advance
1 Jun 2008 at 10:53 #2 marmalade marmalade Associate Joined 18 Oct 2002 Posts 1,768 Location Victoria OZ /Germany/UK Get another filter! Or better - use a filter faceplate on your master socket.
1 Jun 2008 at 11:36 #3 tolien tolien Caporegime Joined 16 May 2003 Posts 25,365 Location ::1 Are you connecting the filter to the filtered side of the other filter?
1 Jun 2008 at 11:58 #4 Paul11 Paul11 Soldato OP Joined 28 Sep 2003 Posts 10,407 Location London tolien said: Are you connecting the filter to the filtered side of the other filter? Click to expand... as far as i remember, there are two extensions coming off the master socket. one to the internet, and one to the phone line. so i assume that no, the filter is on a different extension to the pc
1 Jun 2008 at 12:15 #5 tipsy tipsy Associate Joined 23 Feb 2004 Posts 1,393 Location Greenside/Tyne & wear ---------------Filter to phone | | master socket-------- | | --------------Filter to internet ---------------Filter to phone | | master socket------(splilter from master to diy extension) | | --------------Filter to internet on all used sockets there should be a filter, so it should look like the above no matter what.
1 Jun 2008 at 12:17 #6 milkinc13 milkinc13 Soldato Joined 16 Apr 2006 Posts 3,213 Location Basingstoke could be a broke splitter so try another
1 Jun 2008 at 12:34 #7 mejinks mejinks Soldato Joined 28 Oct 2002 Posts 5,045 Location Hiraeth I was just going to say, it sounds like a broken filter.
1 Jun 2008 at 12:59 #8 Paul11 Paul11 Soldato OP Joined 28 Sep 2003 Posts 10,407 Location London the noisy line could be a broken filter, but how come the internet wont work with a filter attached ? sounds odd. ill have another look to make sure its all wired up as i say when i go to the location later.
