9 Jul 2008 at 09:09 #1 Balb0wa Balb0wa Soldato Joined 18 Oct 2002 Posts 4,562 Location Chesterfield Last 2 days its not been showing the iplayer bit correct, internet explorer still shows it ok. is it a flash or a java problem? firefox 3 explorer
9 Jul 2008 at 10:14 #2 Nabz Nabz Permabanned Joined 14 Jun 2008 Posts 551 java problem, script error?
9 Jul 2008 at 10:16 #3 tolien tolien Caporegime Joined 16 May 2003 Posts 25,365 Location ::1 It works fine here and more to the point, doesn't use Java. AFAICS it's JavaScript. Try safe mode and/or new profile?
9 Jul 2008 at 10:22 #4 bledd bledd Don Joined 21 Oct 2002 Posts 46,890 Location Parts Unknown what extensions do you have installed?
9 Jul 2008 at 10:42 #5 Balb0wa Balb0wa Soldato OP Joined 18 Oct 2002 Posts 4,562 Location Chesterfield i dont have any extensions on, thing is ive not altered anything since its been like that, was fine on sunday
9 Jul 2008 at 10:57 #6 bledd bledd Don Joined 21 Oct 2002 Posts 46,890 Location Parts Unknown should install adblock plus, then select 'easylist' subscription for it, removes all ads from pages. the internet is really messy without it -won't fix your problem though, use toilen's advice to fix your prob first
9 Jul 2008 at 11:06 #7 Balb0wa Balb0wa Soldato OP Joined 18 Oct 2002 Posts 4,562 Location Chesterfield il try adblock thanks, seems to be ok now the bbc page, hmmmm
