- 7 Nov 2006
- Devon
I'm trying to listen to a premiership match through the UK Radio player gadget for the windows vista side bar, but when i try it says that it cant for contractual reasons although i am in the uk
I can listen to the matches on the radio player off their website, so is there any way to fix this so i can listen to the matches through the vista side bar gadget?
Thanks.
Thanks.
