BBQ Parts
7 Aug 2012
Hi All,
Just sorted out the garage and I can't seem to find the second "hinge and pin" for my bbq which is rather annoying.
I'm after another one of these;
https://imgur.com/jsXfj3z
The bbq is a GBC1440WPE.
Not had much luck Googling, however I could be searching the wrong thing!
Cheers
Swain90
A proper bolt with a shank, some spacer washers and 2 nuts to lock against each other would work too as suggested above if you’re lucky enough the diameter matches a common bolt size.
Engineer snob in me knows people say bolt when they’re thinking of set screws.
I've given it a temporary fix at the moment with a rather skinnier sized bolt, however I think I'm going to have to make a trip to Homebase/B&Q to get a larger bolt.
I'm 99.9% sure the gf has thrown it out iby trying to "tidy" the garage :-\
Thanks for the replies!
Your mistake is clearly allowing the girlfriend into the garage. My wife only ever comes in for an escorted visit :D:D
