Hi all,
i5 750 overclocked to 3.2 GHz (160 * 20). Issue is that base clock (BCLK) is resetting to its default value (133MHz) after the system has slept and resumed (as reported by CPU-Z). Only way to get it back to 160 is to reboot.
This happens whether the following are enabled or not in BIOS:
* C1E
* C3/C6
* EIST
and enabling/disabling "hybrid sleep" in Windows makes no difference. The system is stable (1hr+ IBT "maximum") at the overclocked settings completes with core temperatures around the 60C mark.
CPU: i5 750
Motherboard: Gigabyte GA-P55-USB3
Turbo boost is disabled. Vcore is 1.25V and VTT is 1.2V (both set manually).
Any ideas?
Edit: This should quite clearly have been in the "Overclocking" section. Sorry mods.
* C1E
* C3/C6
* EIST
CPU: i5 750
Any ideas?
