BD-Rom wont eject ?
25 May 2011
Hi I just installed my new BD-rom drive the other day and it seemed fine, for some reason now though it just wont eject at all! I have pressed the front button as well as doing it via right clicking and selecting eject, in my computer, but still no luck
Any ideas on what I can do or try ?
Something inside it? Does it have a little hole on the front you can put a paper clip inside? That should open it.
Try rebooting your machine if you already haven't. I've experienced drives that wouldn't open and this fixed it, although I must admit that it had a disc in the drive when the issue occured.
I would say drivers but i don't know how the signal to eject the disk tray is transmitted. Try unplugging the cabels and plugging them in again?
