It's simply a target number for the signal-to-noise-ratio (SNR) of your line.
The lower the SNR, the higher your connection can sync.
Some lines are better quality than others, so your line may be stable with a lower SNR...or not.
Only thing you can do is try it and see where you can get to before your line becomes unstable.
One thing to note: Sometimes your line will seem stable in terms of maintaining a sync/connection, but it may be getting so many errors "behind the scenes" that your lower SNR and higher sync/connection speed is actually performing slower than it would do if you had a higher SNR.  Once again, all you can do is test and keep an eye on your error count in the router.
