- 7 Nov 2004
- On another planet
For the past few weeks i have had allot of connection problems,I keep getting the message on my bebox saying you connection is down ,check connectivity.It will say this for a couple of mins then reconnect,but when playing on xbox live its been doing it all the time,A couple nights ago on xbox live soon as a match started on cod4,i would get connection interrupted then the screen would freeze for a few minutes then say you need to be connected to xbox live to play.I am wondering if its the bebox thats got a problem.I loose connection about 10 times a day for a couple minutes then reconnects.
this is what it says when it goes down
Your DSL connection is down.
Verify if your Thomson Gateway is correctly connected to your DSL line. For more information consult your documentation.
ive noticed it disconnectiong when i am browsing the net,i can be connected on msn and chatting but soon as i open a browser and start doing stuff it pops up with that.
