- 5 Jul 2007
Fitting this to my new Asus lga1700 board today turned into a nightmare, I was shocked how unsuitable it was.
There was a bit of fiddling to get the right parts together for lga1700 fitting but my real troubles began when trying to fit it to my new board even with some 45 years experience. The first thing I noticed was that the heat pipes collided with the top VRM heatsink causing it not to sit flat against the processor. Then when fitting the fan I was again shocked to find it not only stopped any use of the first ram slot (fan was lower than the memory cards !!) but pressed hard against the card in slot 2 !?!?. I had to remove two rubber strips that the fan was clamped against hence now its a little loose fitting.
How was this advertised as suitable for lga1700 !?!?
