Hi Guys
We are currently offering a free Be Quiet! Pure Wings 2, 120mm Fan with every Be Quiet Dark Rock Pro 3 cooler we sell.
Stock is due this time next week and this offer is available while stocks last!
Be Quiet! Dark Rock Pro 3 CPU Cooler + Free Pure Wings 2 120mm Fan @ £65.99 inc VAT
Dark Rock™ CPU coolers have long been category leaders, and now the significantly upgraded Dark Rock Pro 3 is even more powerful. This virtually inaudible double-tower CPU cooler puts famous be quiet! SilentWings® technology in your PC where it really counts. They are excellent for overclocked systems and demanding multi-graphics platforms.
Dark Rock Pro 3 offers top performance-to-noise ratio and the highest reliability available. Improved cooling efficiency (250W TDP) and really silent operation (only 26.1dB(A) at maximum speed) mean this cooler strikes the perfect balance between cooling and serenity —truly silence and performance without compromises.
Immensely high cooling efficiency • Improved dynamic wave-contour cooling fins with small dots on the surface increase air circulation and contribute to high convection efficiency without raising overall noise • Enhanced double-tower layout offers reduced weight and enables high cooling power • Support of additional 120mm fan for extreme cooling performance (free fan clips are included in the scope of delivery) • Seven high-performance heat pipes with copper lining and aluminum caps carry heat to the optimal location on the cooling fins, maximizing heat conductance • The immensely high cooling capacity of 250W TDP offers low temperature even at peak performance • New arrangement of heat pipes enhances the cooling capability
Virtually inaudible operation • Two SilentWings® PWM fans (front: 120mm, inner: 135mm) with advanced copper core fluid dynamic bearing and dynamically-balanced impeller provide optimal cooling with deep serenity • Inner 135mm SilentWings® PWM fan features nine airflow-optimized fan blades and an innovative 6-pole motor for smoother operation and less vibration • Decoupled fan mount with vibration-isolating elements on the heat sink • Noise is at scant 26.1dB(A) even at 100% PWM function
Specifications:-
- Dimensions: 137 x 163 x 150 mm (W x H x D)
- Material: Black nickel plated copper (heat pipes), black nickel plated aluminum (bottom panel, slats, top panel)
- Weight: 1,197 g
- Heatpipes: 7x Ø 6 mm
- Fan:
- 1x 120mm Silent Wings PWM (max. 1700 r / min, 93.3 m³ / h, 2.1 mm H 2 O, 21.5 dB (A))
- 1x 135 mm Silent Wings PWM (up to 1,400 U / min , 113.8 m³ / h, 1.23 mm H2O, 20.8 dB (A))
- connection for both fans: 1x PWM
- total volume: max. 26.1 dB (A)
- Compatibility:
- Intel Socket 775, 1150, 1155, 1156, 1366, 2011
- AMD Socket 754, 939, 940, AM2, AM2 +, AM3, AM3 +, FM1, FM2, FM2 +
- Manufacturer Warranty: 3 years
Only £65.99 inc VAT.
ORDER NOW
Be Quiet! Pure Wings 2, 120mm Fan @ £9.95 inc VAT
The Pure Wings 2 family fans are unique in their class, combining outstanding reliability, silent cooling, and a great price-for-performance ratio.
It’s impressive how much quiet technology the German engineering team has crammed into these fans at this amazing price. They are the ultimate reason to put well-known be quiet! silent cooling in your PC if you haven’t already done so.
The Pure Wings 2 120mm model combines all of the above essential features. It provides maximum cooling airflow and operating noise levels down to a silent 19.2 dB(A).
The increased air pressure makes the fans especially recommended for use in water cooling and air cooling setups.
Features:
- Practically Silent Operation
- Nine silence-optimized fan blades with high airflow capabilities reduce noise-generating turbulences while increasing air pressure
- Very quiet operation even at maximum speed, with noise of 19.2 dB(A)
Specification:
- Product conception, design and quality control in Germany
- Perfect choice for Home and Office PCs, Gaming and Multimedia systems
E- specially recommended for use in water cooling and CPU cooling builds
- High-quality rifle bearing technology contributes to a very long lifespan of up to 80,000 hours
- Three year warranty
- Technical specifications:
- Dimensions: 120x120x25mm
- Nominal voltage: 12V
- Voltage range: 5-12V
- Speed: 1500rpm (+/- 10%)
- Noise emission: 19,2 dB(A)
- Airflow: 51,4 CFM, 87 m³/h
- Connector: 3Pin Molex plug
- Lifespan: 80.000hrs
Only £9.95 inc VAT.
Free when purchased with a Dark Rock Pro 3
ORDER NOW
Specifications:-
- Weight: 1,197 g
- Fan:
- Compatibility:
ORDER NOW
Features:
Specification:
Only £9.95 inc VAT.
ORDER NOW
