Im looking to change my ram 4x4gb to 2x8gb. I found corsair vengeance pro which are 45mm tall so not sure if they would fit. I must be blind as I cant find this information anywhere. Thanks in advance
If you look at these pictures of the Dark Rock Pro 4 you can see that G.Skill Trident Z is under it. They is listed as 44mm on G.Skill website so only 1mm difference.
You will have to move the front fan up a few mm though. What case are you using ?
This Hexus review also confirms the same thing. Scroll down to the bottom of the review. They are using an Asus Z370 Hero board. They state that they had to move the front fan up a few mm.
