Hi
I have just tried to upgrade to a core i7 with an asus p8p67 motherboard and am using a Be Quiet dark rock advanced cooler.
When I go into the bios the CPU fan speed is only reading as 600ish rpm and the CPU temp is about 41 degrees C.
I am sure that the fan is fitted correctly and have used arctic silver paste.
Is there a setting that I can adjust to speed up the fan as I know it can do 1500rpm at 100%. Any ideas on what is going on here would be helpful.
