OcUK Staff
OCUK are pleased to announce we have been made a master partner with be quiet!. be quiet! make high quality, low noise products throughout their range, with focus on silence and performance without skimping on quality.
As a master partner, it means we'll be offering as near as the full range of be quiet!, and some tasty exclusive deals too, like the exclusive launch deal we are offering on the Silent Base 800 : -
BeQuiet Silent Base 800 Silver Case & FREE Pure Rock CPU Cooler Bundle @ £99.95 inc VAT
Unique performance and usability
be quiet! Silent Base 800 Silver offers the perfect symbiosis of noise prevention and cooling performance, a good usability and an extensive capacity for high-end hardware.
The most important features include:
• Meticulous air circulation design and adjustable side panel vents provide outstanding airflow control that improves cooling while reducing noise-causing and performance-robbing turbulence, leading to truly excellent cooling performance
• Sound insulation material, anti-vibration mounting elements, and three pre-installed Pure Wings 2 fans that contribute to amazingly quiet operation
• Tool-free mounting and generous space for advanced hardware and cable management support first-class usability
• Product conception, design and quality control in Germany
The design team’s mission was based on the principle “form follows function”, and so every last detail in the Silent Base 800’s design has a functional purpose. It is truly a superior case ideal for high-end gaming gear and quiet systems.
Specifications:-
- Form factor: ATX
- Motherboard compatibility: ATX, Micro-ATX, Mini-ITX
- Case size incl. stands (W x H x D), (mm): 495 x 266 x 559
- Case size excl. stands (W x H x D), (mm): 495 x 230 x 542
- Color options: Orange, Black, Silver :
- Weight (kg): 9.31
- USB 2.0: 2
- USB 3.0: 2
- HD Audio I/O: 1
- Expansion slots: 7
- Covers: ABS Plastic
- Side panel: 0,7mm Steel
- Front panel: ABS Plastic
- Stands: Nylon, Fiber
Drive bay capacity:- 5.25" x 3, 3.5" x 7, 2.5" x 4
HDD cages total: 2
Removable HDD cage: 2
Relocatable HDD cage: 1
Pre-installed fans:-
- Fan front: 2 x be quiet! Pure Wing 2 |140mm 1,000rpm
- Fan rear: 1 x be quiet! Pure Wings 2 | 120mm 1,500rpm
- Dimensions (L x W x H), (mm): Front: 140 x 140 x 25, Rear: 120 x 120 x 25
- Fan speed @ 12V (rpm): Front: 1,000, Rear: 1,500
- Noise level @ 12V (dB(A)): Front: 18.8, Rear: 19.2
- Air flow @ 12V (cfm / m3/h): Front: 61.2, Rear: 51.4
- Air pressure @ 12V (mm H2O): Front: 0.76, Rear: 1.25
- Voltage range (V DC): 5–12
- Input power (W): Front: 1.08, Rear: 1.04
- Input current (A): 0.09
- Connector: 3-pin
- Lifespan (h / 25°C): up to 80,000
Optional fan installation:-
- Fan mounting locations: 7
- Top (mm): 2 x 140/120
- Bottom (mm): 1 x 140/120
- Side panel (mm): 1 x 120
Compatibility:-
- Optional water cooling system (Radiator in mm): Front: 120/140, Rear: 120, Top: 120/140/240/280
- CPU cooler dimensions without fan in side panel (mm): up to 170
- Airflow channel: Top, Bottom
- Special cooling feature: Side panel with adjustable 3 in 1 air intake
- Maximum dimension incl. bottom fan (mm): 160
- Maximum dimension excl. bottom fan (mm): 290
- Standard (mm): 290
- Without middle HDD cage (mm): 400
- Dimensions, package: (L x W x H), (mm): 651 x 305 x 572
- Gross weight, package (kg): 11.06
Pure Rock is be quiet!’s CPU cooler which is excellent for silent multimedia and graphics applications, and for anyone who wants a category-beating price-to-performance ratio.
- High 130W TDP cooling efficiency
- Mounting kit which allows assembly from atop the mainboard
- Four high-performance 6mm heat pipes with aluminum caps
- A silence-optimized, nine blade, 120mm be quiet! fan
- PWM variable speed operation to help balance cooling and quietness
- Compact design for easier and more convenient installation
- Compatibility with all current IntelR and AMDTM sockets
- Product conception, design and quality control in Germany
- 3-year warranty
Specfications:-
- Dimensions (with fan): 121 x 155 x 87.5 mm (W x H x D)
- Dimensions (without fan): 121 x 155 x 62.5 mm (W x H x D)
- Weight (with fan): about 660 g
- Material: Copper (base plate, heat pipes), aluminum (fins, top panel)
- Heatpipes: 4x Ø 6 mm
- Fan: 120 x 120 x 25 mm
- Speed: max. 1,500 r / min
- Volume: 19.1 / 22.1 / 26.8 dB (A) at 600/900/1400 U / min
- Air flow: max. 87 m³ / h
- Connection: 4-pin PWM (220 mm sleeved)
- Compatibility:
- Intel Socket 775, 1150, 1155, 1156, 1366, 2011, 2011-V3
- AMD Socket 754, 939, 940, AM2, AM2 +, AM3, AM3 +, FM1, FM2, FM2 +
Only £99.95 inc VAT.
ORDER NOW
BeQuiet Silent Base 800 Black Case & FREE Pure Rock CPU Cooler Bundle @ £99.95 inc VAT
be quiet! Silent Base 800 Black offers the perfect symbiosis of noise prevention and cooling performance, a good usability and an extensive capacity for high-end hardware.
Specifications:-
- Form factor: ATX
- Weight (kg): 9.31
- USB 2.0: 2
- USB 3.0: 2
- HD Audio I/O: 1
HDD cages total: 2
- Connector: 3-pin
Compatibility:-
- 3-year warranty
Specfications:-
- Compatibility:
ORDER NOW
BeQuiet Silent Base 800 Orange Case & FREE Pure Rock CPU Cooler Bundle @ £99.95 inc VAT
be quiet! Silent Base 800 Orange offers the perfect symbiosis of noise prevention and cooling performance, a good usability and an extensive capacity for high-end hardware.
Specifications:-
- Form factor: ATX
- Weight (kg): 9.31
- USB 2.0: 2
- USB 3.0: 2
- HD Audio I/O: 1
HDD cages total: 2
- Connector: 3-pin
Compatibility:-
- 3-year warranty
Specfications:-
- Compatibility:
ORDER NOW
Added to that we've got a trio of great deals on TWO, going live this afternoon : -
BeQuiet Straight Power 10 600W '80 Plus Gold' Modular Power Supply @ £87.99 inc VAT
be quiet! Straight Power 10 provides a new level of silent performance for systems that demand whisper-quiet operation without compromising on power quality.
Features
- Virtually inaudible SilentWings 3 135mm fan with improved fan frame
- Big funnel-shaped fan opening of the PSU case induces high airflow intake
- 80PLUS Gold power efficiency (up to 93%)
- Four high-performance 12V-rails
- Power signal stability unmatched in its class
- Powerful GPU support with up to four PCI-Express connectors
- Premium 105°C-rated parts enhance stability and reliability
- ErP 2014 ready
- User-friendly cable management reduces clutter, improves cooling airflow
- 5-year warranty
Specifications
- Model: 600W
- Partcode: BN235
- EAN: 4260052183687
- Voltage / Frequency: 100-240Vac / 50-60Hz
- ATX 12V 2.4 / EPS 12V 2.92: Yes
- Dimensions (L x W x D): 160 x 150 x 86
- SilentWings Fan: Yes
- Noise level (dB(A)) at 20 / 50 / 100% load: 10.6 / 10.9 / 20.2
- Efficiency (%) at 230V: Up to 93%
- 12V Rails: 4
- Active PFC: Yes
- OCP, OVP, UVP, SCP, OPP, OTP: Yes
- Certifications: 80 PLUS Gold, AMD CrossFireX
- Energy Star 6.0 compatible: Yes
- ErP2014 ready: Yes
- Lifetime of fan at 25°C (h): 100,000
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 4 x 6+2-Pin-PCIe
- 9 x SATA
- 3 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
Was £95.99 Inc. VAT
Only £87.99 inc VAT.
ORDER NOW
BeQuiet Pure Power L8 630W '80 Plus Bronze' Modular Power Supply - With 120mm Silent Wing Fan Built in @ £64.99 inc VAT
The Pure Power L8 series proves that true affordability means peerless dependability and best-in-class features — not cutting corners and settling for less. Whether you are assembling a very quiet higher-powered system, building a better multimedia or dual-GPU gaming system, or upgrading an existing PC, your build will benefit from the premium features be quiet's German team has designed into this PSU.
Features
- Silence-optimized 120mm be quiet! fan with durable Rifle-Bearing-Technology
- Certified 80PLUS Bronze efficiency (up to 88%)
- Modular Cable Management with sleeved cables for reduced clutter and better airflow. All-in-one cable with SATA, HDD and FDD connector
- Supports multi-GPU systems (400-700W)
- Meets energy-saving requirements of Intel C6/C7, ErP 2013 and Energy Star 5.2 guidelines.
- Ready for Intel ® Haswell TM platform
- Stronger +12V rails increase power stability
- Full suite of top safety protections defends against over-currents, over- and under-voltages, short circuits, overheating and overloads, thus safeguarding valuable components
- German product conception, design and quality control
- Three year warranty
Specifications
- Continuous power (W): 630
- Model: BN182
- Voltage / Frequency: 100–240Vac, 50–60Hz
- ATX 12V 2.31 / EPS 12V 2.92: Yes
- Dimensions (LxWxH): 160 x 150 x 86
- be quiet! fan (mm): 120 Silent Wings
- Noise level (dbA) at 0 - 100% load: 15-25
- Efficiency (%) at 230V: up to 88
- 12V Rails: 2
- PFC: Active
- Certifications: 80Plus Bronze, AMD CrossFireX
- Energy Star 5.0 Compatible: Yes
- ErP2013 ready: Yes
Connectors
- 2 x 6+2-Pin-PCIe
- 2 x 6-Pin-PCIe
- 5 x SATA
- 4 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 3yr
Was £74.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
BeQuiet Dark Power Pro P10 850W '80 Plus Platinum' Modular Power Supply @ £164.99 inc VAT
Dark Power Pro supplies are already renowned as the world’s quietest PSUs in the high performance category. The Dark Power Pro 10 850W model takes that a giant step further with an all-new design topology that delivers 80PLUS Platinum performance.
Add to that an unparalleled array of enhancements that augment this unit’s compatibility, convenience of use, reliability, and safety, and the result is simply a power supply without equal. Simply put, this is the highest-powered, most technologically-advanced power supply be quiet! has ever built.
Features
- Virtually silent operation achieved through a broad array of meticulous optimizations, including use of be quiet!’s custom-designed 135mm SilentWings® fan
- SilentWings fan features airflow-optimized fan blades, fluid dynamic bearing with copper core and high quality IC motor controller for the quietest possible operation
- 80PLUS Platinum certification and up to 94% power conversion efficiency let you do more work with the same power and reduce your power bills
- 850 Watts of continuous power provide deep power reserves for demanding computing applications
- Cable management with extra long cable reach simplifies component installation and reduces annoying clutter, increasing airflow and improving cooling in even the largest PC cases
- Overclocking key allows switchover between quadruple independent +12V rail mode and high-performance single-rail operation
- Five Year Warranty
Specifications
- Continuous power (W): 850
- Model: BN203
- Dimensions (LxWxH): 190 x 150 x 86
- be quiet! fan (mm): 135 Silent Wings
- Noise level (dbA) at 20 / 50 / 100% load: 10.4 / 10.2 / 24.2
- Efficiency (%) at 230V: up to 94
- 12V Rails: 4 / 1 (OCK)
- PFC: Active
- Certifications: 80Plus Platinum, NVIDIA, AMD
Connectors
- 1 x 8-Pin ATX12V/EPS12V
- 6 x 6+2-Pin-PCIe
- 1 x 6-Pin-PCIe
- 9 x SATA
- 9 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Was £179.99 Inc. VAT
Only £164.99 inc VAT.
ORDER NOW
Keep your eyes peeled for a Be Quiet competition next week
More details here!
Specifications:-
- Form factor: ATX
- Weight (kg): 9.31
- USB 2.0: 2
- USB 3.0: 2
- HD Audio I/O: 1
HDD cages total: 2
- Connector: 3-pin
Compatibility:-
- 3-year warranty
Specfications:-
- Compatibility:
ORDER NOW
Specifications:-
- Form factor: ATX
- Weight (kg): 9.31
- USB 2.0: 2
- USB 3.0: 2
- HD Audio I/O: 1
HDD cages total: 2
- Connector: 3-pin
Compatibility:-
- 3-year warranty
Specfications:-
- Compatibility:
ORDER NOW
Specifications:-
- Form factor: ATX
- Weight (kg): 9.31
- USB 2.0: 2
- USB 3.0: 2
- HD Audio I/O: 1
HDD cages total: 2
- Connector: 3-pin
Compatibility:-
- 3-year warranty
Specfications:-
- Compatibility:
ORDER NOW
Features
- ErP 2014 ready
- 5-year warranty
Specifications
- Model: 600W
- Partcode: BN235
- 12V Rails: 4
- Active PFC: Yes
Connectors
- 4 x 6+2-Pin-PCIe
- 9 x SATA
- 3 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 5yr
Was £95.99 Inc. VAT
ORDER NOW
Features
Specifications
- Model: BN182
- 12V Rails: 2
- PFC: Active
Connectors
- 2 x 6+2-Pin-PCIe
- 2 x 6-Pin-PCIe
- 5 x SATA
- 4 x 4-Pin-Molex
- 1 x Floppy
- Warranty: 3yr
Was £74.99 Inc. VAT
ORDER NOW
Features
Specifications
- Model: BN203
- PFC: Active
Connectors
- 6 x 6+2-Pin-PCIe
- 1 x 6-Pin-PCIe
- 9 x SATA
- 9 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
ORDER NOW
More details here!
