- 28 Jun 2005
Have seen a few reviews of these and they look decent. They're showing as pre-order in the store so any idea when these will be in stock?
The high powered version of the 120MM use just under .5amp at 100%, most headers can handle 1 amp. If you are going to daisy chain i would use a powered hubVery keen on these to replace my bequiet fans, however the fan controller takes 6 fans, I will be replacing 10 silent wings which are daisy chained into various PWM headers.... would that cause an explosion or something? (going into a ARGB header on z690 maximus).
I guess they're based on the Pure Wings, or at least they look to be.Seem to have nice ARGB lighting with nothing great in performance department .. so overall a good ARGB fan choice according to VSG, and I find his reviews to be some of the best.
Would love to try them out and see (no pun).
