Be quiet silent wings 3
22 Apr 2014
Cornwall, UK
Hey so I've got 4 of these and I plan to install them when my new motherboard arrives,
They come with two fittings.
1. Anti-vibration
2. Hard plastic
I'm guessing it's better to use the anti vibration ones? Instructions aren't clear on what is what lol.
1. Anti-vibration
2. Hard plastic
Anti vibration are great to fit mate I've used both but prefer tha anti vibration so easy to install fans
Arent they both anti vibration if you mean the pin type fitting vs the screw type?
The screw type still has a material that makes contact with the case.
Personally I use the screw type, I remember previously trying to remove the pins and it was a pain I'm sure one of them snapped where as screws are just screws
Thanks for the information, yeah I guess they are, I just read the information from the instructions and written the exact wording be quiet call both attachments, but I'll probably uss the screw ones though
