BE QUIET! STRAIGHT POWER E7 600W POWER SUPPLY - ONLY £58.99 INC. VAT
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Be Quiet! are known for the quality and now you have own a high quality PSU from them for only £58.99. Bargain!
Be Quiet! Straight Power E7 600W Power Supply @ £58.99 inc VAT
Try having a look at your power supply through our eyes: Namely as the heart of your computer! After all, what makes us humans so effective? That's right, a strong heart that reliably provides our body with the right amount of energy at the right time. STRAIGHT POWER E7 series of Be Quiet! Power Supply Units with that same principle in mind. STRAIGHT POWER E7 constantly adjusts the amount of energy it supplies to reflect the current workload facing your computer: from nearly zero watts in stand-by mode to the full bore when working with High-End applications. Up to four separte 12V cables are on hand to provide a stable power supply to all your systems's key components. That helps your entire computer work at the same levels of high efficiency that the STRAIGHT POWER E7 achives!
STRAIGHT POWER E7 from be quiet! This PSU boasts the 80 PLUS® Bronze certificate and is notably quiet running thanks to the be quiet! SilentWings fans. The compatibility with the latest ATX 2.3 technology, multiple PCIe slots as well as a high degree of efficiency (up to 89%) prep your PC for top performance. The new, elegant STRAIGHT POWER E7 design with a top-quality surface and innovative ventilation grate provides better air circulation and rounds out the product's appearance. That means that STRAIGHT POWER E7 is naturally a worthy addition to the accustomed premium quality of the be quiet! family.
- Power: 600W
- Operating Temperature: 0 to 40°C
- Dimensions: 16.0cm (W) x 15.0cm (D) x 8.6cm (H) - Weight
- Safety Features: OCP, OVP, UVP, SCP, OTP and OPP
- 80 Plus Bronze Certified
- ATX 12V 24-Pin : 1x
- 4-Pin Molex (HDD): 5x
- 4-Pin Floppy (FDD): 2x
- S-ATA: 6x
- 4-Pin 12V: 1x
- P8 Connector: 1x
- 6-Pin PCI-Express: 1x
- 6+2-Pin PCI-Express: 2x
- 3-Pin Fan Connector: 2x
- 4-Pin Fan Connector: 2x
- Warranty: 3 Year Warranty
Arriving Monday 9/08/2010
Only £58.99 inc VAT.
ORDER NOW
