be quiet! System Power 9 600W 80 Plus Bronze Power Supply CA-13V-BQ
29 Jul 2021
Southampton
This is advertised as having "4x 6+2-Pin connectors for multi-GPU systems" but the one I ordered recently from OC only has 2. Not a problem for me and the psu is running my system with a temp borrowed rtx 3070 ti with no issues but could be a problem for someone.
Return it. You haven't got what you paid for plus should you need to RMA it at some point you may run into difficulties as the PSU will be different to the one you actually ordered.
I have just done a search for the code (CA-13V-BQ) that is on my account and that is the B grade version that is in OC clearance section for £60, £5 more than the one I ordered. I was charged £55. It's not worth the hassle to change it as it does the job.
