Be quiet! Yin & Yang - Twin systems
29 Jan 2016
Scotland
Special Thank you to Be quiet!, INTEL and MSI.
What's the plan?
d I recently won the INTEL Techmesh Challange with a be quiet! 802 case, and decided that with the prize money i wanted to do twin systems.
One Nvidia/Intel and the other Nvidia/AMD
The theme is Yin&Yang, Black/White, AMD/INTEL
The white build is to be fully watercooled.
The black build is Air cooled GPU, with an AIO.
Essentially, showing the versatility of the Be quiet! 802 case and hoe important that is when it comes to case modding.
System Specs
White system
MSI Z690 Carbon Wifi DDR5
Intel Core i9 12900k
Nvidia RTX 3090
64GB DDR5 @5400mhz
All custom white EK Cooling
7TB Storage
be quiet! Silent Base 802 Window Black Case
be quiet! 1000w Pure Power 11 FM Power supply
be quiet! Light Wings PWM High-Speed fans
be quiet! Silent wings 3 fans
Black System
MSI B550 Plus gaming
AMD Ryzen 5 5600X
Nvidia RTX 3070 OC
32GB DDR4 @3400mhz
be quiet! Silent Base 802 Window Black case
be quiet! 850w Pure Power 11 FM Power supply
be quiet! light wings PWM High-Speed fans
be quiet! Silent Wings 3 fans
be quiet! Pure loop 360mm AIO
Modifications
Firstly, with this perticular case, modding is super easy, no fancy machinery is even needed.
Simple hand held rotary and you got yourself a job well done.
First things first, removal of the PSU Shroud, cut out the centre, and filled with colored resin.
there's a little bit of bleed from the Y in Yang, and light bleed on the YIN, these are easily fixed.
Will update again shortly with product images.
- Craig
Product photo's!
First up
Be quiet! Pure Power 1000w FM
this power supply is part of the Be quiet! essential Range and comes in a lovely low price point.
Be quiet! Light Wings 3 pack PWM High Speed Edition
Without going into troo much detail, these things are bloody beatiful. The lighting is just phenominal compared to what i usually use. Bright, but yet, subtle enough to not burn your eyes.
Not Saying they look bad in black, but these are also going in my white system, so they also needed to be white.. ;)
Be quiet! need to make these in white, i'd be having them on every radiator on my build.
more modding and more products to follow :)
- Craig
More hardware images!
The mighty Intel Core i9 12900k!
The waterblock for the CPU is the EK Water Blocks EK-Quantum Velocity² D-RGB. Painted White!
With hydronaught CPU paste applied!
the fittings are EKWB lignum, painted white!
Main Drives will be there little beauty! in both systems
The CPU cooler for the black system will be this! The Pure Loop from Be quiet!
TheCPU Liquid i chose, is the EK cryofuel Solid White!
Should help the system stand out.
More to follow
-Craig
