Bean bag filler
10 Jan 2012
UK
I'm ordering a HIGH BACK Bean Bags Bag, which contains 7.5 cubic feet of bean filling (the normal little BB shaped kind).
This type of filling gets squashed over time and eventually will go flat and uncomfortable (I'll be using it as a desk/gaming chair, so I will be sitting in it for a long time so it will go flat quickly)
So I'm thinking about ordering 5KG of shredded RELAX FOAM which comes in a bag that is : L135 x W37 x D37 in dimensions and either replacing the beans with the foam or mixing them together (which I have heard is the best thing to do to get the best of both worlds)
Its not just a bag on the floor, its a gaming "pod" with a back and neck support, so I will be sitting in it exactly like a normal office chair.
http://i17.photobucket.com/albums/b61/beanbagbazaar/Beanbag Store/PODVLBROWN.jpg
http://i17.photobucket.com/albums/b61/beanbagbazaar/Beanbag Store/PODVLBLACK.jpg
If anyone who has bean bags could give some insight, would be much appreciated :)
Why not just use a chair or sofa?
I'm pretty sure that spending long, constant periods sitting on a bean bag isn't going to do you any favours.
I suffer from pains if I sit on chairs for long periods, and bean bags are the only thing that doesn't hurt, the doctors actually suggested them to re-leave the pain. Also I don't have room for a sofa :)
The desk I have to use is 45cm in height and this bean bag would sit me at
That is going to be damn uncomfortable, I feel sorry for your back.
edit - Just seen above, don't know why you didn't mention that in the OP.
Why is your bum sore? I doubt this is going to help in the long run.
Normal chairs are uncomfortable.
Even ones with back support.
My brother bought the bean bag I want to buy and it was actually the most comfortable thing I have ever sat on for over an hour.
Its not just a bag on the floor, its a gaming "pod" with back and neck support, so I will be sitting in it exactly like a normal office chair (except lower down ofc) and I can lean back in it and my back is supported.
I'm the same and cannot sit in any chair for too long without getting back ache, Will try a beanbag to see if it helps. Thanks :D
Search HIGH BACK Bean Bags Bag GAMING POD CHAIR
Comfy as hell
And yeh its anoyying as hell, my back is killing me right now...feels like I've just done like a million sit ups...
