My bebox often randomly disconnects/restarts. This happens every time I start xfire too. What alternatives should I go with?
Ok I'll be getting the DG834GT. Do I need to do anything particular to set it up with BeThere?
Thanks a lot. Do I install the custom firmware before or after following that guide?
ADSL Link | Downstream | Upstream
Connection Speed | 2490 kbps | 767 kbps
Line Attenuation | 70.5 db | 40.3 db
Noise Margin | 3.8 db | 5.2 db
