Bed adhesive
14 Feb 2023
Scotland
What are the general thoughts on bed adhesive?
Dedicated bed adhesive, hairspray, Pritt stick, WHY ?
Used dimafix before, excellent .
Some decentish results using cheapo hairspray but not convinced .
Used nothing at all sometimes worked sometimes didn't
I can get 3DLAC for £10.89 or dimafix for £ 24.47 (£4.50 of that is delivery) same size.
Is the dimafix worth the extra, can I go buy an adhesive at a local (ish) shop, Edinburgh,Scotland?
Really can't see the point in not using an adhesive, cost of use is trivial compared with the cost of the filament/electricity involved in a multihour (even day) print
if it fails nine tenths of the way in due to bad bed adhesion.
I used 'Got to by Glued' for a bit trying to get PETG to adhere better. Made one heck of a mess that's hard to cleanup.
Now, I just up the bed temperature by 10 degrees and that seems to work much better.
Shall try that Bug, at the mo' pretty much everything gets a bed temp of 60 maybe up that to 65, 66 etc till 70 don't want to go much higher than that with PLA,shall try printing a Benchy or calibration cube or ... (something quick).
Nope, that’s exactly how it is. The surface will get damaged if you don’t use an interface material as removing the print is a bugger.
So why would you glue it if the bed is allready super sticky. :confused:
Edit :-Oh right because your not using it as glue your using it as "release agent",
I picked up some Polymaker PolyTerra and I just can't get it to stick well at all,
it's just PLA but for some reason it resists sticking consistently which I just don't get.
Probably teaching you to suck eggs, but you tried a higher bed temperature regardless of what it's listed at?
I've had a few cheap rolls that allegedly called for 60 degree beds and wouldn't adhere at all unless I added something to make them adhere or I pushed the bed temp up to make the first could have layers stick.
