my temps are 32c idle... the reason is i have set my min fan speed to 62% in bios and set cpu fan target to 50c.. compared to 87% min and 40c target the last time!! which i quickly went through the pro 7 in 3 months.
ive been running my pro at full speed on and off for 2years its been fine so far it did 6months in one build and has done a few weeks here n there in other builds and has done 3 months in this build been ok so far but its got abit noisy recently :S
I've been running the pro in my current PC at duty cycle (100%) since something like september 2006 and its still going strong I have a backup ACF7 pro waiting in the wings for when/if it does die. Got 3 of them when they were on special offer for like £8.99 each.
I don't know about the MX stuff but I use AS5 and its pretty good straight off - tho temps do drop another 2-3C within the next couple of days.
cheers guys.. do you think i got a duff pro then? can these things stand 100% 24/7 for a few years then? what was your fan target temp then as the small print says to set at 65c!! i thought that was a bit high!
