You can find 120mmx 27mm (finished size) if you hunt around, but I just use some off the shelf 125mm x32mm from TP, & adjusted the skim when I put a doorway in here.
Funny things door linings Macca, different brands, different finish sizes, I had them from 27mm & up to 38mm thickness, & the width has been just as bad.
Just got a new lining for the outside toilet, & the wall is 100mm single block, picked up a lining set on my travels & it 's said 108mm width, nearer to 103mm I say, totally useless as I was going to skim the wall.
The architect here messed up the total thickness of the build up of the walls when drawing up his door schedule, I assume he assumed skim coat when we are T&J, so every lining is 5mm too big.
