New to this site and found it very good already so thanks.
So as you can see from my sig ,my rig is now ancient. 2007 was a good year!
I have a computer room again and want to update and play some games Witcher 3, battlefront, Elite but heck my rig don't run nothing anymore.
I reckon the only salvageable bits are the 500Gb SSD, HDD and the DVD RW.
I was thinking something on the lines of
My basket at Overclockers UK:
Total: £720.00
will need a case that it will fit in, nothing fancy, as it sits under the desk and a PSU, also is the water cooling overkill? have always OC'd CPU and thought I might need it.
If you can see any way to shave a few pounds off the price that would not go amiss either as I have been looking at those gaming chairs
thanks
- 1 x MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card= £284.99
- 1 x Intel Core i5-6400 2.70GHz (Skylake) Socket LGA1151 Processor - Retail= £155.99
- 1 x Gigabyte GA-Z170XP-SLI Intel Z170 (Socket 1151) DDR4 ATX Motherboard= £118.99
- 1 x Kingston Fury Black 16GB (2x8GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit - Black (HX424C15FBK2/16= £79.99
- 1 x Corsair Hydro H60 V2 High Performance Liquid CPU Cooler (CW-9060007-WW)= £59.95
- 1 x Arctic Silver 5 Thermal Compound (3.5g)= £8.99
Total: £720.00
thanks
