Hi all,
Last built a pc about 2 years ago now and its starting to slip a fair bit.
Need to know where to start as ive fallen behind somewhat (used to be right up to date on latest specs
Current system is Sempron 2800 (clocked at 2.2ghz) socket a, a crud pcchips M/b 1.5gb 333mhz ram, AGP X800xt PE GPU, just got a 19" w19b HP monitor.
Where do i start!
I really can't be bothered to build pc's anymore although i know it will be cheaper, its not the building that bothers me its the speccing new components and checking if they work ok together etc
so is this system any good??
http://www.overclockers.co.uk/showproduct.php?prodid=FS-035-OK
or this
http://www.overclockers.co.uk/showproduct.php?prodid=FS-029-OK
which will perform better?
Thanks for any help chaps
Lee
)Current system is Sempron 2800 (clocked at 2.2ghz) socket a, a crud pcchips M/b 1.5gb 333mhz ram, AGP X800xt PE GPU, just got a 19" w19b HP monitor.
Where do i start!
so is this system any good??http://www.overclockers.co.uk/showproduct.php?prodid=FS-035-OK
or this
Lee
