Hey all, thought I'd come here for some advice/opinions, recently I've been thinking about getting a sound card, other than getting one just to have (which is a contributing factor) one actual reason is because I've been getting a slightly annoying issue with my on-board sound.
When I have my headphones connect into the back-panel all is fine, I can swap out my headphones/2.1 speakers all day no issue, but for some reason if I add a microphone into the equation I'l bump into an issue where I'l have no sound for a period of time, it goes like this, say I'm using my speakers or headphones and want to game up so I switch to my bitfenix headset (won from here ), I connect the headphone jack and everything is okay, connect the mic in and realtek pops up saying Ive connected a microphone device - but its after this that I'l lose all sound from my system, I cant open any sound-panels or info at-all - it's like my system sound hangs and takes awhile to respond (best solution I've found is just to open up a video/music file and wait until my audio comes back, which can take up to a minute if its being especially annoying, same issue arises if I'm using the front jacks on my case, also when this happens I can disconnect the mic and just connect the headphones but I still have to wait for sound to re-appear, again it looks like once the issue starts it takes my system (I'm assuming onboard sound) a while to actually properly register changes and deliver audio.  At this point just always have my mic plugged in and swap from my headphones to headset when needed (time it takes seems reduced but I still have the no audio issue).
So whats the verdict? sound-card go-ahead, I'm not using anything fancy for my listening equipment in-case that affects sound-card suggestions
Headset - Bitfenix flo - http://www.overclockers.co.uk/showproduct.php?prodid=SP-003-BX
Speakers - http://www.acoustic-energy.co.uk/#!aego/cgnd
Headphones - http://en-uk.sennheiser.com/audio-headphones-stereo-hifi-closed-hd-215
Thanks for having a look and I look foward to any suggestions and advice.
), I connect the headphone jack and everything is okay, connect the mic in and realtek pops up saying Ive connected a microphone device - but its after this that I'l lose all sound from my system, I cant open any sound-panels or info at-all - it's like my system sound hangs and takes awhile to respond (best solution I've found is just to open up a video/music file and wait until my audio comes back, which can take up to a minute if its being especially annoying, same issue arises if I'm using the front jacks on my case, also when this happens I can disconnect the mic and just connect the headphones but I still have to wait for sound to re-appear, again it looks like once the issue starts it takes my system (I'm assuming onboard sound) a while to actually properly register changes and deliver audio.  At this point just always have my mic plugged in and swap from my headphones to headset when needed (time it takes seems reduced but I still have the no audio issue).So whats the verdict? sound-card go-ahead, I'm not using anything fancy for my listening equipment in-case that affects sound-card suggestions
