Beeps from motherboard while PC is on?
25 Jul 2005
My pc has recently started making single beeps whilst it is turned on. I've googled it, but havent found anything useful yet. Anyone have any idea what could be up?
It's a Epox-9NPA+ SLI board
CPU temp 39
System temp 38
It dosent do it very often ( once or twice a day, and everything seems to be working fine, it's just a bit strange)
Thx in advance.
One of the most common is when your playing shooters and you press too many keys at once on the keyboard, it isn't this right? ;)
I'm no expert, but from experience check all PCI cards and the like are removed and reseated properly, check all power leads are connected ok.
Also try disabling any CPU smart fan or Qfan control in the bios.
Download Memtest86 and check your ram for errors.
Good look chief.
