Begginer Needs Overclocking help
B&W
B&W
3 Oct 2003
Birmingham
Hi Guys.
Never overclocked before and would like some good assistance before i attempt it.
My spec is the following
Q660 @ 2.40 Ghz
Sapphire HD 5850
2GB Ram
two 320 gb hard drives
Windows 7 Ultimate SP1
530W BeQuiet PSU
Motherboard is a standard packard bell Foxconn
i want to increase the speed but i need to know what to first.
PS: i cant edit stuff in bios, wn't let me do it for some reason
Regards
B&W
the bios is phoenix award bios.
BIOS Type: Phoenix-Award
BIOS Date: October 1st 2007
BIOS ID: 10/01/2007-PT890-8237A-6A7L8FKEC-00-None
BIOS OEM: PT890M02 PBSFC2MB.P10 100107 - PBSFC2MB.P10
Chipset: VIA 82C327 rev 0
SuperIO: Unknown
Manufacturer: Packard Bell BV
Motherboard: iXtreme X2712
this is a very basic explanation of overclocking
its basic maths. your Q6600 is rated at 1066mhz. you always divide this number by 4 so 1066/4= 266, this is your fsb. (or cpu frequency)
then your processor (cpu) has a multiplier of 9 (or cpu ratio)
so 266 x 9 = 2394mhz or 2.4GHz, your stock speed
unlink your ram, so it stays at stock speeds, you can overclock the ram later.
this means leave it at 800mhz or 667mhx etc...
can you raise the fsb? yours is now 266. try rising it to 280
boot into windows
download realtemp and coretemp (google them)
install and run them
then download intel burn test (ibt) and run it.
have a look in task manager and notice how much free ram is listed.
in IBT set threads to 4 (for 4 cores) and then click on custom ram and enter an amount just below the free amount.
eg. i have 2520mb free ram. so i enter 2500 into the custom ram.
run the test for 5 passes. for now,
and then at final speed you want, run for 50 passes
keep an eye on temps (do not let it go over 75.c)
or download prime95 and run the torture test/large fft's
if test runs fine, go back into bios, and change frequency (fsb) to 300 and repeat the tests.
keep doing this in 20mhz steps until windows will not boot. then just go back a step (remove 20 from the fsb) to the last stable frequency,
or
just raise the cpu voltage a couple of levels. it should now boot.
its a balancing act, higher voltages will get you higher fsb, but it will also give you higher temps.
my B3 revision Q6600 needs 1.39v in the bios to get to 3.3ghz.
if yours is a G0 revision, you should be able to get this speed at a lower voltage
the Q6600 is fine upto 1.5v
the trick is to do this step by step, and not go straight to eg. 400 (400 x 9= 3.6ghz), just take your time.
also for some reason using the x 9 multi, i couldn't get past 3.0ghz
so i dropped it to a x8 multi and i got it to 3.3ghz easily.
get the cpu maxed before increasing the ram speed
and please, have a proper cpu cooler before going down this route
boot into windows
or
thanks mate, however, ive run into a problem before i can attempt ANY of this, my Phoenix award bios is locked........i know the password, i enter it, it goes in but i cant edit nothing. why is that.
Probably because its a Packard Bell mobo, some PC makers like PB lock their boards down so you can't tamper with them.
meh need a new mobo anyway to complete my new system, then it will be even more daddy
