Merry Christmas everyone from Greece!
Recently i built a new system compiled from old and new staff: i7 9700K, Asrock H370 HDV mobo, RTX 3070 an 16Gb DDR4 Ram 3600CL16. Motherboard doesnt support overclocking the CPU and only supports memory up to 2666. Right now i havent enabled XMP, so RAM runs at 2133 or sthing, the lowest anyway.
Question is , do i enable XMP from BIOS? Will it use a Profile @ 2666 CL16, or try to run @ 3600, probably can't since its not supported and then fail to boot? Should i choose an "AUTO" option or manualy select 2666?
Many , many thanks!
Many , many thanks!
