Hi,
I read the max safe temperature for Intel chips was 1.3v. What I done was set my CPU volts to 1.285 and then OCCT tested my computer starting at 4.4GHz. At this it crashed within 1 minute of the test. I then lowered to 4.3GHz on the same volt and it is still running the test as we speak with max temperature in OCCT of 90, 89, 88, 82 on all four cores. HWMonitor shows a package temperature of 92. It hasn't stopped the test so can I assume this is stable and my next step would be reducing the core volt until it becomes unstable? (to lower the temperature?)
Thanks
Thanks
