Hi there, I am a recent new member to this forum, I am looking for a little help in building my first gaming computer i have a MacBook Pro which I use at the moment but I know that it isn't suitable for gaming so I have decided to build my own instead of buying a pre built one, I mainly would like to use it for rpg games such as world of Warcraft but would also like to get rid of my Xbox and get into to playing games on the pc as well I do use steam and have a few games on there also which my MacBook cannot handle I would like to be able to play games in full graphics but it's not really essential so, I have already bought the case it does include a 750w power supply but I have been told that usually power supply's included with cases are not very good I also have had a look around at some parts, I am thinking of building it over the next few weeks installing and buying each part weekly. I was wondering if these parts would be compatible and would work together, bare in mind I am a beginner I was wondering if someone could tell me if I they would be compatible or if I could substitute parts for other parts you could recommend where I could save money I have a budget of around £400 not including the case, mouse, keyboard or monitor. Here are the parts I have found so far do I need any other parts? I would prefer to run windows 7 on the pc as well if someone could recommend parts or even a setup I could chuck into my case for what I need that would give me both great performance at a good price I know that a budget of £400 is quite low but I could also invest in second hard parts to save costs any help would be appreciated, I am really good at buying parts that don't fit, here are the parts I have been looking at so far:
Nvidia gtx 750
i5 4690k
Kingston hyper x beat 2x 8gb
Msi z97 gaming 5
Seagate 2tb hardrive
And here are my case specification and details:
Specifications
Available Colour: Black
Dimension (L / W / H) 435 x 196 x 420 mm
Side Windows Included
Weight (Gross) Net Weight: 3.6 kg
Motherboards Micro-ATX & ATX
Rear Expansion Slots: 7
Power Supply: 750W ATX (Included)
Mains power cable not included
Drive Bay Support:
5.25" Drive Bay 2 (Exposed)
2.5'' / 3.5" Drive Bay 3.5'' x 1 (Exposed)
3.5'' x 3 (Internal) & 2.5" x 0 or
3.5'' x 2 (Internal) & 2.5'' x 1 (Internal)
Front I/O Panel:
1 x USB 3.0
2 x USB 2.0
1 x HD Audio
Cooling Support:
Front: 120mm x 1 (Optional)
Rear: 120mm x 1 (Black Fan Included)
Power Supply Info:
Power Supply Included: 750W PSU
Compatibility: ATX
Wattage: 750 Watts
Dual Rail 12V
AC Input 230Vac
Active PFC
Fan Type: 120mm Silent Red Fan
Cables Included:
1 x 24 Pin Main ATX
1 x CPU 8-Pin 12V
4 x SATA Power
1 x 6-Pin PCI Express
3 x 4 Pin Molex power
1 x Floppy Drive
Nvidia gtx 750
i5 4690k
Msi z97 gaming 5
Specifications
Drive Bay Support:
Front I/O Panel:
1 x USB 3.0
2 x USB 2.0
1 x HD Audio
Cooling Support:
Power Supply Info:
Compatibility: ATX
Wattage: 750 Watts
Dual Rail 12V
AC Input 230Vac
Active PFC
Cables Included:
1 x 24 Pin Main ATX
1 x CPU 8-Pin 12V
4 x SATA Power
1 x Floppy Drive
Just get the 64-bit version of either.
