beginner question - Best Distro for needs
5 Feb 2016
have a old dell PC fixing up for selling and need a distro.
what is the best disto for simple web browsing, office based applications and general browsing?
mint or Ubuntu? or is there something else would be cleaner and more efficient
its a athon 64 x2 5400 2.8ghz dual
onboard graphics chip.
ram ( not labelled and not finished cleaning etc to check)
500gb sata
Personally not a huge fan of Mint; Cinnamon is unpolished and a little tacky for my tastes, and I don't see the point of yet another layer of abstraction from Debian when Ubuntu covers virtually every other major DE. My choice would be Ubuntu MATE.
thanks that's what I was thinking. used Ubuntu a couple times before and I seems to be decent for what it is need for
mint is so so had a bit of use with ubuntu and seems decient
Like everyone has said, the Ubuntu flavours. They are well made and tend to have the best community support.
If you want to get your feet really wet, take a look at Arch and a tiling window manager ;)
I always thought an Ubuntu based distro was the best since it is the one always recommended. After a few years though I found there are much better ones.
I would recommend ROSA 7 right now.
Well, most people recommend an Ubuntu distro because it's usualy the only one they have ever used properly, or only one they have ever used.
I recommend ROSA7 because I have used a lot of different distros in the last 2 years and this has been the most comfortable one I have come across.
And don't go listening to people who say "this is the closest feeling you get to windows" etc, because the idea of using Linux, is to get away from Windows.
My advice, is to follow yashiro's advice.
