im getting more and more interested in all this watercooling buisness.
I looked at the zalman reserator 2 and really liked the looks. Good temps from smal pipes (dont like the somewhat massive pipes i see some people with lol.
However i have a few questions.
How often would i have to replace the water :-S as obviouslyt with a fan you'd only have to giv it a blow out with a compressor to get dust out. I dont want to be replacing the water every few days or even months :-S
I want to cool the cpu, chipset and gpu with water cooling, this i feel would be the best way to keep the whole system runnign well. My motherboard is a DFI Nf4 sli. However i am only running one card and may plan to upgrade later.
I want to use the same thickness tubes as the zalman kit as its a bit more flexible and easier to work with, thew onlky downside the the zalman was the fact if i went to a lanparty i'd have to carry a seperate massive box to cool mhy PC i'd want to fit it inside my case, however I have just bought a Antec 900 case so any advice on the best system that would fit in my case would be excellent.
Think thats everything. Thanks in advance guys!
Matt.
Matt.
