Beginners guide to UML
21 Oct 2009
Yes I know this is in the wrong section but programming had 4 people viewing the whole section!
Hello GD,
I need to learn UML for my uni course this year. See below for explanation.
Could you recommend online guides and programs I can download for free to aid me? I can hire out books from the library but I will need to request them hence free online info would be ideal.
I have seen a few programs and links but I have no clue what is best. The program they use at uni is called Visual Paradigm.
Thanks in advance
Ash
Explanation:
This year I'm studying real-time software engineering as one of my modules. A prerequisite for this module is software engineering which I didn't do last year. However, I'm going to do it this year. So I'm doing modules designed to be taken one after the other in the same year. Once I get further on in real time, I will have covered everything I will need for it in software engineering. However, UML is the first topic in real time and I won't have learnt it in software to be able to do it.
Make sense? No? Oh well!
24 Jan 2007
Bristol
23 Dec 2010
Luckily for you, I'm still at University - so don't fret.
I don't use any specific software to make my UML diagram, but I know a lot of people use Microsoft's Visio - which you'll be able to obtain freely once you register at University and get access to Microsoft DreamSpark.
It's not as hard as people tend to make out, it's just the simple case of practice (and some reading) makes perfect.
When it comes to books I would highly recommend Martin Fowler's excellent UML Distilled. It was an absolute godsend for me as I was unable to get my head around it at first, comes with a nifty few pages for reference at the start as well as having 'easy-to-read' information about certain elements further in.
If you've got anymore questions to ask, don't be afraid to do so - I'll be checking this thread every day for a the next week or two.
Just a helpful tip as well for you, but you're coming across as a little aggressive on the opening post - you might not do it on purpose but it's showing.
OP
21 Oct 2009
Really sorry about that :/ I didn't realise but I'm not trying to be. I come to this place because I know I always get good advice. Just last time I opened a C thread in GD and I got a flood of good replies without it being moved instantly. Sorry again.
I've got access to DreamSpark so I will check out Visio. I've not done the research into programs for it but does it make a difference whether you use a Mac or PC? I've been told you get some issues when you code but does that apply to UML (I'm a newbie at this - I'm used to coding in PASCAL and I use MATLAB a lot)
I'll also rent out that book and have a good read through. Thanks for taking the time to reply especially with the links.
11 Aug 2005
UML is one of those things you learn at uni but then nobody actually wants to use - because businesses don't see it as profitable.
Read this then forget about it IMO
http://www.ibm.com/developerworks/rational/library/998.html
I tend to disagree with this statement. UML is crucial in designing scalable software which meets the clients needs in a cost effective and well thought out manner.
My advice would be to learn and use UML as much as you can. Your university lecturers will appreciate you planning your coursework and projects with use case & class diagrams and it will ultimately make you a much better programmer when you graduate and start work.
11 Aug 2005
Care to explain how UML helps with that?
I've seen so many developers dive straight into coding an application without actually designing it properly. UML helps with this by allowing you to create a design document with use cases (for a start).
If you get the design right at the start, you don't have to then go back and shoe-horn in functionality to an already established object model which could have been designed properly at the start of the project.
That's my opinion anyway - may be wrong, just what I think from my experience in software development.
23 Dec 2010
This,
The amount of software devs which write code which can't be maintained is too damn high.
24 Dec 2010
Surrey
I also studied it at Uni, but it is something that a lot of developers don't even bother doing.
UML is a part of the design stage, I have mainly used it to break down what I am going to be doing. It is also a really easy way of showing what the inputs/outputs of the system will be to the customer (usually they have no idea how to turn a computer on, let alone code something).
Main ones I use are Activity / Sequence diagrams, Class diagrams, Use case diagrams (easy way to show customer)
4 Mar 2010
Coventry
I learnt UML at Uni too, however I am yet to use it in work projects for coding/system designing. I have however found places to use certain diagrams I learnt for other things, Activity/Sequence diagrams have played a nice part in explaining/detailing/random things to people.
I say, read the basics and forget most of it. Understand the diagrams a bit just incase you will need them, but that is likely slim.
