Behemoth's mATX Build - Build Pics - 56K Go away !
1 Dec 2002
Cornwall
Now that I've got a bit of spare time to do this before hitting the sack I thought I'd post up some pics to show how it all went.
My weapons of choice
Hmmm it's small in there !
For an mATX board it does pack a lot of features !
Board mounted in the case, CPU in place
Hmmm could be a problem with the RAM later
I was right, a VERY tight fit !
Perhaps I should have bought 2 x 4 Gig modules, but nevermind got them all in
GTX 460 in, Soundcard in too, thinking at this point modular PSU should have been ordered
Thinking I might be alright for coolong in this little case
It lives :D
I know you've all seen it, but the finished article
Phenom 2 X2 Unlocked all 4 cores, standard clocks, 8 gig DDR3 Corsair RAM, Gigabyte GTX460 OC2, 2 TB HDD - very cool, very quiet, very stable.
Ideally before I move I want to crack it open and tidy the cables, but very happy with the build none the less.
Thats a G510 and MX518 mouse :)
Just discovered I had the PSU in the wrong way round so have kust put it the other way :)
Oddly enough Stulid, will be living in weston next month :)
Looks nice, you should be able to fit some good length GPU's in there. Quick question - why's the CPU Heatsink mounted to pull air from north to south?
Surely this is very counter productive (heat dissipating upwards and all + you've got a space for a nice exhaust fan if you turned it to pull the cool air flowing into the case from the big front fan and then out the back using a 120mm in the rear fan mount, or just none) ?
Also have you got the 2TB drive mounted up in one of the 5.25" bays or in the hdd bay in the front of the case?
My 3.5 HDD's are in the correct bays for the HDD's as they are not pictured as they weren't in the case when I took the pictures.
Well I've been minitoring the temps on my CPU and to be honest it really isn't suffering from it being mounted that way round, if it become a problem I'll change it round.
I have this case too and did a build last novemeber :)
It's an awesome little beast and I love seeing other builds into it.
Did you give routing the cables round the back of the motherboard tray a bash?? On mine I forced all the cables on my modular psu round the back which seemed to help.
Iv found no need to run a rear fan too, the big one at the front and a decent cpu cooler is more than enough!
Case is big enough for some massive graphics cards too! Iv got a 6870 (which I thought was big) but there's a good few inches spare if longer is needed
I saw - I'd still like to see another in there :D You need to buy a new motherboard :P
Can't afford to buy another mobo or a GTX 460, not that I really need it. Can't say I've found this PC at all slow, it's certainly got the grunt for what I play on it.
I've re routed all my cables behind the mobo tray now, temps have dropped by a few degress too.
