As above.
My old CRT tv has just given up(its done well for 15ish years use,lol)
So im off Overclockers tomorrow to replace it.
Its main use is video games/dvd's, and seeing as a 19" monitor is cheaper than a 19" "tv", im going for a monitor. And the ThisWeekOnly Belinea is a bargain.
I will be using the xbox 360 with a vga cable, and dvd with a scart to vga converter.
So my question is, does anyone use this monitor for xbox360? Does it work well, with it being 16:10 widescreen?
Any screen shots?
Its only in a small-ish room btw, so a 19" WS should do fine. The old Crt was only 20"
Thanks
Any screen shots?
Thanks
