Belinea 22" and 360 resolutions
15 Nov 2002
Birmingham
Is anyone running their 360's through this monitor, if so what resolution are you using? At the moment im running it at 1360x768, is this best?
Cheers
Hi I have exactly the same set up and asked exactly the same question not long ago (see here ) . I found that 1360x768 made the graphics tear in GoW, now I have it set to 1280x768 which is perfect (there's no real difference in quality having it at a lower res).
With the monitor resolution ratio being 16:10 this is the best res to go for. I'm not sure what GuruJockStrap is on about, that doesn't seem to be a widescreen resolution.
Thanks
Matt
Only got it today so ive only tried 1360x768 with R6 and PES6, i didn't noticed any tearing but i'll put Gears in and see what it looks like.
/QUOTE]
1280x1024 widescreen gives a squashed image (if your monitor does 1:1 pixel mapping you can check it out) but which looks normal when the monitor stretches is horizontally (20" monitors are native 1680x1050).
1280x1024 outputs the highest res to the screen.
Thats what I found. 1280x1024 gives the highest pixel density on screen and in my eyes looks the best on my Dell 2005FPW.
Best thing is to try out all the resolutions and see which one you find best.
