Belinea 22" problem
  • Thread starter Thread starter spp
  • Start date Start date
spp
spp
15 Nov 2006
Hi all,
I got the Belinea 22" widescreen about a month ago to replace my old 19" and I'm very happy with it. I have however noticed that sometimes text can appear as if it is fuzzy. When I look at the text with a magnifying glass the green lights are flickering, while the red and blue are not. If I turn the monitor off, and then back on again the problem has gone, ie the green lights of the text are not flickering. It happens maybe 10-20% of the time. Does anyone else suffer this problem?
I just got mine this week. Can't see any flickering, but if it does i'll report back. However, I did test it in work through a KVM switch (with power leads everywhere around it) and there was double vision on the left hand side of the screen, kind like a ghost image you'd get on a TV with a bad aerial. When I got home and used a decent cable, the picture was perfect.
Try another cable?
thanks for the reply guys. It doesn't seem to have done it these past couple of days, so I'll just see how it goes.
