Belkin ADSL High speed modem wireless
sjohal2006 said:
Also, is this a good router/modem? ... Might aswell ask whilst im at it
RJ-11 is just the little phone plug :p
Belkin is a good brand, had one running at home no problem, but other people will tell you otherwise.
L0L.... Think I should edit the first post... cant look that stupid! :p
Erm, It will be working alongside a Belkin Wireless G Desktop card...
And I have brought that already, so I think I have to get this Belkin.
Will a Netgear DG834G work with that Belkin Desktop card? ... (PCI)
Thanks Will! ;)
It should all be compatible if they follow industry standards.
But the Belkin you've chosen is a "Super G" one, does your Belkin wireless card also have this technology?
the Netgear also gets good reviews around these parts
Erm, I wasnt going to get the exact one I linked to.
I was getting the Wireless G 125 ADSL Modem Router
I believe its just ADSL
The one I linked was ADSL2...
F5D7633 - Thats the model Im getting though... looked the same you see :o
My card just says Wireless G 54mbps 2.4ghz - This should work with it shouldn't it... It was £25
