This card constantly disconnects on XP64, reboot and its fine, using 64bit drivers from their site but still cant get over the problem, if you download the standalone driver it doesn't support 64bit OS and wont install.
So I have to use the bloatware package which I disable and use windows software to connect.
does anyone have any answers if not a wireless PCI card that does work in XP64.
Thanks
Thanks
