Belkin N+ with Xbox Live - Help!
19 Oct 2002
Pembrokeshire
I just bought a Belkin N+ Wireless Modem Router (BT connection).. installation was easy and everything was working well until I tried my 360..
The 360 is not connected wireless but with a cable and will not connect to Xbox Live. when I do the test it says not enough MTU but the default settings are higher anyway..
I've had a quick look around and read someplaces that this router is not compatible with Xbox live, which seems strange.. Just wondering if anyone has had experience with this and is there any easy solution ? (other than taking the router back).
Thanks
Jase
