I purchased a number of the Belkin UPS's on This week only from OcUK. 1 of which i intended to use on my shuttle SB95P v2.
Ive got a bigger system in my other room, much higher spec with more hard drives etc, which takes the UPS to 40% load whilst idleing. This system works fine during the UPS test, and if you unplug the UPS from the mains.
However with the shuttle, its only at 23% load, and it turns off the instant you click on test, or unplug the UPS from the wall. I have tried switching them over so its not a fualty UPS unit.
Has anybody else found these dont work with shuttles? And would it be the same with most UPS's or is there a spec I would need to look for which will work?
