http://www.bimmerwerkz.com/forum/audio-electronics/e46-wire-guides-complete-21429.html
Radio Connector --
1 - yellow/red left front +
2 - blue red right front +
3 - yellow/black left rear +
4 - black (not used)
5 - violet/white 12 volt switched (HU power line)
6 - blue/black right rear +
7 - white / red Not Used
8 - brown/orange left front -
9 - red/green + terminal battery connection
10 - white Not Used
11 - brown/orange right front -
12 - brown/orange left rear -
13 - grey/red illumination
14 - brown/orange right rear -
15 - brown ground
16 - white remote amp turn on
Amp Connector -- The Connector is laid out as follows
13_21 __ 34_42
12_20 __ 33_41
11_19 __ 32_40
10_18 __ 31_39
09_17 __ 30_38
08_16 __ 29_37
07_15 __ 28_36
06_14 __ 27_35
_ 05 _____ 26
_ 04 _____ 25
_ 03 _____ 24
_ 02 _____ 23
_ 01 _____ 22
1 - brown rear left speaker -
2 - yellow rear left speaker +
3 - blue/brown front left woofer -
4 - blue/white front left woofer +
5 - red/green terminal 30 from fuse F41
6 - green positive activation for subwoofer from HU
7 - white subwoofer switched to sub amp pin 2
8 - blue/black rear right + AF radio from HU
9 - blue rear right - AF radio from HU
10 - white antenna switching signal from HU
11 - blue/black front right tweeter +
12 - blue/brown front right tweeter -
13 - yellow rear right tweeter +
14 - blue/green negative activation for subwoofer to sub amp pin 6
15 - yellow/black from spatial sound button on dash
16 - brown/orange rear right - AF radio from HU
17 - brown/orange front right - AF radio from HU
18 - Not Used
19 - black/green speedometer signal to sub pin 7
20 - black/white speedometer output from instument cluseter control module
21 - blue/yellow rear right tweeter -
22 - blue/brown front right woofer -
23 - blue/red front right woofer +
24 - brown rear right speaker -
25 - blue rear right speaker +
26 - brown ground to chassis
27 - Not Used
28 - Not Used
29 - brown/orange rear left - AF radio from HU
30 - brown/orange front left - AF radio from HU
31 - yellow/black rear left tweeter +
32 - yellow/brown rear left tweeter -
33 - yellow/red front left tweeter +
34 - yellow/brown front left tweeter -
35 - Not Used
36 - Not Used
37 - yellow/black rear left + AF radio from HU
38 - yellow/red front left + AF radio from HU
39 - blue/white front left mid-range -
40 - white front left mid-range +
41 - blue/green front right mid-range -
42 - green front right mid-range +
Subwoofer Amp --
6_7_8_9_10
1_2_3_4_5
1 - green positive activation from amp pin 6
2 - white subwoofer switched from amp pin 7
3 - Not Used
4 - brown ground to chassis
5 - red/green Terminal 30; power from fuse F41
6 - blue/green negative activation from apm pin 14
7 - black/green Speedometer output from amp pin 19
8 - Not Used
9 - Not Used
10 - Not Used
