Benchmarker that doesn't Crash (Advice Pls.)
12 Jun 2011
Near Overclockers
Hi all
Can anybody recommend a free graphics benchmark program that is more reliable than Heaven and 3DMark?
As far as I am aware, my graphics setup is fine and can still run all games on Ultra settings. However, these two programs just keep crashing.
I don't need anything with fancy movie clips running (unless they are necessary); just something that will "do what it says on the tin".
Best regards to all
AD
Hi all
Best regards to all
AD
Yes, OCCT. Copy my settings. (ignore memory usage) This will sniff out an unstable core overclock on your gpu.
OCCT detects tiny artifacts that would otherwise be hard to see whilst watching a short benchmark sequence or whist normal gaming. If it produces any errors, you know it's not fully stable.
Heaven and 3Dmark do exactly what it says on the tin, they test for unstable systems.
If your setup can not run these at stock settings, you really need to find out why and get it fixed ASAP before your PC crashes while you are doing something important on it.
yep +1
Yes, OCCT. Copy my settings. (ignore memory usage) This will sniff out an unstable core overclock on your gpu...
Good tip, I'm giving this a go now, I usually loop heaven for a while to test stability.
Why shader level 3 rather than the recommended 7 for amd gpus though?
Shader 3 works best apparently. I find i can pass rounds of Unigine with an unstable core but this sniffs it out in minutes. Not sure how effective it is for the memory though.
Yeah, the memory is what I'm most interested in testing. It'll run heaven for ages, then blackscreen when gaming if the memory is too high.
I'm up to 1130/1580 on the 270 :) It won't let me put any more than 1.225 volts on the core though, which is holding it back.
BTW crashing in game benchmarks can be down to memory errors if you clocked the fx via bus and have a sketchy memory controller. So if you know the GPU is fine, i would start looking at the CPU clock and voltages and maybe the memory.
I tried that OCCT stress test, Got a **** ton of errors on my 24/7 overclock of 1150/1500, tried maxing the voltage out in afterburner to see if that fixed it but nope, still got loads :(
Strange thing is though I've never once noticed anything at all in games or all the benchmarks I've used.
It's a shame Afterburner doesn't allow higher voltages than 100mv, i'd use GPU Tweak but i love all the recording and monitoring stuff you get with Afterburner.
Yeah cheers for the suggestion. I'm pretty sure it's the vram overclock though, as knocking it down 50 hz to 1550 solved the problem. Just blackscreened at 1580, so think I've found the max safe limit of 1570.
I think it applies it as soon as MSI AB opens up (might apply it before it opens but that'd be odd, since the shortcut doesnt open MSI AB), though touching the slider will knock it down to 100mv again. Basically, what i quoted is the shortcut target but double clicking the shortcut wont open anything. To open MSI AB i have to use the shortcut and then open MSI AB normally, if i want to apply the +250mv.
